[?]: ET200S CPU Data Bus Error
kiks
Post by kiks »
Hello Everybody!! (sos) (nuser)
Please, Does any body can help me?
I am trying to configure a ET200S 151-8 PN/DP CPU + DP-Master Interface 138-4HA00-0AB0 + PM-E 24V 138-4CA01-0AA0+ 6 DI 131-4BF00-0AA0+3DO 132-4BF00-0AB0 but when I download the hardware configuration SF LED turns on on red and CPU Stops. I already try to fix the problem changing PM-E and terminator but doesn't work.
Using only CPU + DP-Master the system works;
Using only CPU + PM-E + I/O system works;
Mix of DP-Master and PM-E does not work. SF Leds in CPU and PM-E turn on on red!!
My Software version is 5.5 SP2
Firmware version for CPU is 3.2
Any help is welcome!!
(fback)
Thanks in advance!!
Kiks
