B&R Upload project from PLC to PC
другие контроллеры
Papiksub
Post by Papiksub »
Hi All
Is anybody know how can i connect with PLC B&R X20 and upload project from there to PC.
I can't deal with the Automation studio (I think there is generally such an option is not provided).
It turns out that B&R only in appearance - a beautiful piece of plastic.
Or am I wrong ????
georg_demmler
Re: B&R Upload project from PLC to PC
Post by georg_demmler »
work with BuR since two years - which version of AutomationStudio did you use? 2 or 3 or 4?
And why did you upload a program?? This is with version 3 not possible.
Perhaps the program is in a special folder on the compact flash.
George
Papiksub
Post by Papiksub »
I work with AS 3.0.90.20.SP2
I need download existing project from PLC because i am not sure that copy on my PC really last copy.
georg_demmler
take your programm and open in the configuration view the "CPU.SW". Now go online. If everything works perfect the softwareparts will be marked which are different from the CPU.
And you find the date of downloading.
But with Version 3 you have no change to take an upload.
But I will ask BuR in Munich if there is another way to take an upload.
George
Papiksub
Post by Papiksub »
Ok
Thanks a lot. I was connected and looked "CPU.SW" and found stupid different - many different things in my project and in the PLC.
