Rslinx - problems to install in win 8
dunga-abc
Post by dunga-abc »
Hi, anyone has a way to install and works RSLinx in win 8 64 bits ............
NowanH
Re: Rslinx - problems to install in win 8
Post by NowanH »
According with Rockwell webpage, RsLinx is compatible with all versions of Windows 8, except:
- Windows 8.1 Industry Professional 64-bit
- Windows 8 (home) 64-Bit
- Windows 8 (home) 32-Bit
First check that your version doesn't appear in this list.
Installing RsLinx is a very straightforward procedure. I only found problems in the last releases with a particular dll (Rsedsui.dll) but this problem is solved uninstalling RsLinx, manually deleting the dll file, manually deleting the entry in windows register that points to the dll file, rebooting and installing again.
Can you give more information about the problems you found?
