Dear All,
I have a second hand proprietary machine, that uses the FM357-2 to control a 2 axis movement.
There is a movement pattern xxxx.SPF file, which i need to alter. I have this one the PC. but need to upload it into the PLC.
I am completely new to siemens, and I do not know how to get the file onto the PLC.
I have the Step7 software on my labtop, I have a USB-MPI cable that I can connect to the PLC. but it looks like the STEP7 software is not what I need to connect.
Does anyone know what software I need to upload the .SPF and .MPF files?
Desperate
[?]: Uploading a .SPF file onto a Simatic S7-300
albysoo
razmarand
Re: [?]: Uploading a .SPF file onto a Simatic S7-300
Download package from:
https://support.automation.siemens.com/ ... ype=133100
Install it then open S7 sw. If you don't have the project, make new one and choose PLC/Upload to PC/PG.
Under hw, search your module, right click, object properties, parametrize.
You will see the content of FM with all the directories (main programs, subprograms). The rest is easy.
succes
succes
albysoo
Thank you! Razmarand!
I will try this right now and get back to you.
Albert
Albert
