EPLAN P8 2.4 patch Windows x32x64
				PDLFFALF
				van8x10
Re: EPLAN P8 2.4 patch Windows x32x64
Great! Thanks!
				kestas201
thank you
				Luca
Great job!
This EGF file includes all the add-ons.
				borci0
Is this 1 months time limitation?
				Renan Rocha
Does anybody has a dng file to eplan 2.4?
				borci0
Did you try to change date to November? I think it's not working after 1 months.
				titus95
When you reach the closing date, you should remove SN-U10066.EGF and put the original downloaded, for one month more.
				van8x10
Finally, I've installed successfully the Electric P8 and Pro Panel v2.4 x64!
Tip of the day :
 You need install Microsoft Access 2013 (64 bit) of re-install Microsoft Office 64 bit first!
						Tip of the day :
				jmns
Can someone be more specific about installation. I read text from HASP Emulator for Eplan P8 Windows x64.txt
then I :
1) Copied SN-U10066.EGF into c:\user\public\eplan\common\
2) UAC set to minimum
3) started HASPUserSetup.exe and finished
4) started 10066.reg and changed register
When I started Eplan, got a message "The program 'EPLAN' cannot be started with this license."
Please, help...
						then I :
Please, help...
				aselek
Eplan X64 patch files doesn't work if PC time is set in 2015. I think that, the evaluation time is over. Any body have new SN-U10066.EFF files which is working in 2015.
				titus95
No problems for me, just delete the file SN-U10066.EGF (C: \ User \ Public \ EPLAN \ Common \) and replace the original one supplied with the crack. I do that one time by month and everything is ok. last time on 07/01/2015.
				fermin7
Dear plcers,
I am new at this forum and writing this first post asking you some help about installing the patch for the Eplan 2.4.
I am running win 7 64bit pc. I made the installation for EPlan 2.4 and then I tried to install the patch.
My problem was that I could not find the installation of HL Hasp in order to uninstall it. When I am trying to
install the HASPUserSetup.exe it pop ups a message that a newer version is already installed.
Thank you in advance all plaers!!
				zofim
Hi there,van8x10 wrote:Finally, I've installed successfully the Electric P8 and Pro Panel v2.4 x64!![]()
Tip of the day :You need install Microsoft Access 2013 (64 bit) of re-install Microsoft Office 64 bit first!
Would you be kind to tell us how did u get it?
It would be very appreciated!
				joselu
Good morning ;
I am not able to activate Eplan . The steps I follow are:
1) Copied SN- U10066.EGF into c: \ user \ public \ eplan \ common \
2) Nose UAC program exactly what to do
3) HASPUserSetup.exe started and finished (This step gives me failure , because it says that the program is old )
Please you can clarify me the steps a little more detail .
Thank you.
Thank you.
				Ahmad_k
Does anyone tried the data portal if it is working ? can you download a component to your design ?
				shl235
https://tvzil.us/?m=bbs&bid=torrent_uti ... uid=187429
The installation instructions are 32-bit only.
