[Link] Eplan P8 2.4
Тools, Elcad, Eplan, ...
Luca
[Link] Eplan P8 2.4
Post by Luca »
LINK
It works with the same crack as 2.3. If you have version 2.3 working - just install the 32-bit version of 2.4 and it'll be ok. I had some stability issues with the 64-bit though.
I'm looking for Pro Panel 2.4; Fluid 2.4; PPE 2.4; Preplanning 2.4. If anyone can share :wink:
andyz2005
Re: [Link] Eplan P8 2.4
Post by andyz2005 »
tfgpereira
Post by tfgpereira »
Hello everyone,
Who can arrange the crack for EPLAN V2.4?
thanks
justmember
Post by justmember »
andyz2005 wrote:propanel won't work with the same key as 2.3
-> i am talking about the stand-alone-version
But ProPanel Prof, Preplanning, API not work, cuz key from 2.3 doesn’t work properly.
van8x10
Post by van8x10 »
Yes, the stand-alone Pro Panel v2.4 not run with the v2.3's known emulator. But you can use Pro Panel 2.4 Add-on within Electric P8 2.4 if select Ultimate Licence instead of Professional+.
Luca
Post by Luca »
Hello djto,
I'm aware of this problem. The only solution that i have found so far is that once you open the new eplan you have to wait for [Error:4521] about a hardware conflict. It usually takes from 20 sec to 1 min for this message to appear. After you close it the Eplan starts working as intended - you can make new project, migrate old and so on.
Luca
Post by Luca »
One more tip: the ultimate licence includes only the normal Pro Panel. If you want the extended functions of Pro Panel Professional you have to choose "Eplan component manufacturer package". It's included there.
tak2750
Post by tak2750 »
Luca wrote:Hello djto,
its not working for me (h)
