Need serial for Vijeo Runtime for Windows
Frollo
Post by Frollo »
Hello everybody,
I am searching something for installing Vijeo Designer Runtime on a PC. (version 6.0 or 6.1).
I have found the standalone runtime,
http://www.seupdate.schneider-electric. ... oDesigner/
but it request for a serial... :(
Does somebody knows how to install a ".vdz" project on a PC without this "reference number" and "serial" ?
Schtiel
Re: Need serial for Vijeo Runtime for Windows
Post by Schtiel »
Frollo
Post by Frollo »
It doesn't work with VijeoRuntime for PC 6.1 SP4. (doesn't recognize the code when lanching the runtime ?)
After installation of 6.0 SP3 : It seems that it's ok !
1. First install the runtime 6.0
2. Open Vijeo Runtime Manager on the desktop / Then enter the product type and a valid serial
3. Then choose activate with a code you have already
4. At this point you have to use the “KeyGenUnity” / You have to enter the declaration number, and the computer ID given by the Runtime Manager.
5. at last you have to enter in the KeyGenUnity the ID Product choosen ("AUX 5501" as mentionned by Schtiel) : 5501
6. Authorisation codes are generated, take the first one of the section “Proworks32”
:) Thanks all
I have made screen copies to illustrate the procedure which is not "guessable", there : http://dl.free.fr/j5uSuHbPE (disappear after 30 days of no DL)
Up to now, the task is to understand how to give my project to the runtime
(i have a project file *.vdz, or after unzipping *.SwxCF and a file *.csv for the parameters of the Vijeo project)
(i can't find a "loader" or something like that for the PC...)
Frollo
Post by Frollo »
Erf....
The runtime reject my project, which is compiled with version 6.1.0.293...
I am still searching an authentification code for VijeoRuntime 6.1
Frollo
Post by Frollo »
ok after trying the same procedure on another PC it works with 6.1 !
(clap) :?
kae1
Post by kae1 »
Also works for 6.2 .
Use second code for windows pc , first is magelis ipc.
Anonimozzo
Post by Anonimozzo »
really works on 6.2?
I follow the procedure but when I run the manager it says that the reference is incorrect...
dkhang0406
Post by dkhang0406 »
Hi, Can you guys reup the keygen and the procedure how to get authorization code? all the links died.
Thank you
ZW_Enthusiast
Post by ZW_Enthusiast »
Anyone to please reupload keygenunity
(oo) (oo) (oo) (oo) (oo) (oo) (oo) (oo)
Please!
