Ask for activation Studio V21.03.00 and V21.0.0.0
nhannguyen0804
Post by nhannguyen0804 »
Hi everybody,
I have a package Studio Designer V21.03.00 (which I downloaded from Rockwell webpage - Link was provided for Training Course) and I get a 30 days activation Serial. But now I want to active to use for a long time, so
Spoiler
Try to use the following...
Note*) The new Studio 5000 V21.0.0.0 from now on uses digital signatures to protect the files.
This method will work for now on.
Factory Activation Software 3.51.0.0040
Use FLEXnet Licensing v11.10.0.3 build 96515 i86_n3 (lmgr.lib)
Patch to allow licenses:
Hexedit flexsvr.exe at address E4D0
Replace 55 8B EC 83 E4 F8 81 EC with 33 C0 40 89 45 FC 48 C3
Patch to accept licenses:
Hexedit C:\Program Files\Common Files\Rockwell\FTACommon.dll at address 40FB9
Replace 34 02 with 30 90
Patch to bypass digital signature check:
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ActivationInterop.dll at address 5C86
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\LogixDesigner.exe at address 1DFAF6 (V21.0.0)
Hexedit C:\Program Files\Rockwell Software\RSLinx\RSLINX.EXE at address D9092 (V3.51.10.00)
Replace 0F 85 46 03 00 00 with E9 2C 00 00 00 90
It now shows a message stating that files have been altered.
The following will remove these messages:
Patch to bypass digital signature warning message
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\RSLinx\FTAStub.dll at address FCD
Replace 40 03 with 09 00
Quote:
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
But I can't detective any address which this way shows.
After that, I uninstalled this version to reinstall Studio V21.0.0.0 (link: viewtopic.php?f=41&t=19605 )
and i can't detective and address,too
anybody knows what happens?
Plz help me
tks a lot
I'm not good at english. sorry for inconvenience
nhannguyen0804
Re: Ask for activation Studio V21.03.00 and V21.0.0.0
for more information:
I used Win 7 Pro so the software is stored at:
C:\Program Files (x86)\Rockwell Software\Studio 5000\ , not C:\Program Files\Rockwell Software\Studio 5000\
nhannguyen0804
Hi everybody,I try doing it again, and it worked well
follow this way:
wuddy wrote:Dear nrjdsn
Spoiler
We should to change the RS5K_700.exe to RS5K_000.exe.
You can see in My Computer>Local Disk (C:)>Users>Public Documents>Rockwell Automation>Activations. So double click at ftasystem.lic
Spoiler
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_000.exe" SN=8283999999 \
To check that you've done things right, open yur FactoryTalk Activation Manager > Advanced > Refresh Server. Then click the 'Manage Activations' tab and then 'Refresh Activations'. If all went well, you should now have RS5K_700.exe, RS5K_GLX.exe, RS5K_MLP.exe, RS5K_000.exe,RSLINX.EXE and RSLINX.EXE GW (where GW is Gateway) as an Availible Activation.
the version which i use, is V21.0.0.3 . it work well which this way (though it doesn't have any address which is showed this way, but i used files of nrjdsn for V21.0.0.0 )
But I still don't know how to find some addresses.
I will try this way for V21.03.00 and I hope it's will work well ( for more information: Studio V21.03.00 4.7GB and Studio V21.0.0 only 2.3GB , what is different between them? )
tk for your notice
z01lo
Post by z01lo »
Hi everybody
Can someone upload the Studio v21.03.00?
(oo)
Thanks! (tyou)
pippolo
Post by pippolo »
Tcp
Post by Tcp »
Studio 5000.
I modified all the files using hex editor and I can see all the licenses in the activation manager.
But when I run studio 5000 it comes up with product not activated.
What license number should i use when i install the software.
duckman
Post by duckman »
Have a look in the license manager again and you most probable find that there is no number against the licenses, i.e 10 licenses available. Which indicates you haven't done the cracking correctly. Follow all the activation posts, as they work
Tcp
Post by Tcp »
Thanks for the pointer.
There was all "n/a" for the Total.
flexsvr.exe was not hex edited.
Now it's all good.
robin_hood
Post by robin_hood »
Hi Guys ,
i got 21.03 but after launcher a message appears " violation licencing warning ".
What can i do for that ?
Thanks in advance
THChop
Post by THChop »
I'm having the same issue. How do I get rid of this message? Help will be appreciated. Thanks!
ArchVile
Post by ArchVile »
0x004D95F0
Sorry that should be (offset)D95F0 from 0x74 to 0x75
Hows that for a first post :-P
yankees
Post by yankees »
ArchVile,
which file are you changing?
thanks,
Icek_kos
Post by Icek_kos »
Please, I really need Studio 5000 v21.03 (distrib). It is possible to download?
Abraham_GB
Post by Abraham_GB »
I have the Studio 5000 V21.0 but I need the V21.03, do I need install V21.03?? Somebody has the link to download it??
Thanks for advance
Ronny_Resistor
Re: Studio V21.03.00 and V21.0.0.0 wanted
Post by Ronny_Resistor »
Please provide me with a PM (private message) as to where i can get a copy
Thankyou
qsator
Post by qsator »
New links where download the version 21.03 or 23..... Thanks (oo)
nar2000
Post by nar2000 »
Hi everyone . I need link for download rslogix studio 5000 v21.03. Thank you everyone.
Atrium
Post by Atrium »
Hello (nuser)
I download Studio 5000 V21 with Mega link.
I am looking for a crack, I read the tutorial on the first post but I can't find:
Enabling Software Factory 3.51.0.0040
Use FLEXnet Licensing v11.10.0.3 i86_n3 build 96515 (lmgr.lib)
I find hexedit V4.0.
Someone can load the softwares that missing? please
xtasyorsk
Post by xtasyorsk »
Atrium wrote:I download Studio 5000 V21 with Mega link.
Please show a link
AliFarzam1
Post by AliFarzam1 »
i have the software if someone needs it, can message me
