STEP V12 DON'T HAVE HSC IN THE CATALOG
josuedavidcachi
I HAVE A HSC MODULE 6ES7138-6AA00-0BA0 SIEMENS FOR ET200SP BUT I DON'T HAVE THE COMPONENT IN THE TIA PORTA V12 I NEED HELP OR ANY INFORMATION ABOUT THAT. THANKS
SimaticS7
Re: STEP V12 DON'T HAVE HSC IN THE CATALOG
Dear friend,
when you install engineering software (e.g. Step 7 Basic) you are not finished with instalation. Time is go on and new modules are coming, modules which you don't have in your version of software... You must find and install new hardware support packages (HSP) for your modules, and after that you will find your module in hardware catalog... In some cases you must install newer version of engineering software...
You will find nstallation procedure for Hardware support packages on this page below
http://runplc.com/pdf-manuals/
P.S. On this page you will find PDF: Integrate new modules in TIA portal – Hardware support packages (“RUNPLC” step by step manual)
Best regards
Best regards
