software for S7-400H redundancy application
cordobes998
Post by cordobes998 »
Hi, I need to develop an application wich I have a CPU 417H in redundancy. The networks are Profibus for ET200s and Profinet others.
I have understood that it is necessary to have Step 7 v5.5 + SP* + H-system. It´s ok?
Please someone could tell me where to get these programs?
Thanks so much!
cordobes998
Re: software for S7-400H redundancy application
Thank you for the repply,
I wrote ET200s indicating the "s" as the plural ..... really are ET200M as remote I/O. Sorry for the confusion that I generated.
Anyway, what revision of Step 7 I need?
Step7 v5.5 SP3 support H-CPUs
Insert > Station > Simatic H Station
See Step7 Examples folders
cordobes998
Thanks CoMod! It´s necessary any external H-package software for redundancy? or this tools are included in V5.5 SP3?
Salutte you
cordobes998 wrote:Thanks CoMod! It´s necessary any external H-package software for redundancy? or this tools are included in V5.5 SP3?
All H inside V5.5 SP3.
cordobes998
Thanks a lot!
cordobes998
Dear CoMod, could you confirm me if is possible to work this configuration in TIA Portal? What version? I tried to do it, but I don´t find CPUs 417-5H.
Thank you
cordobes998 wrote:Dear CoMod, could you confirm me if is possible to work this configuration in TIA Portal? What version? I tried to do it, but I don´t find CPUs 417-5H.
TIA portal v13 is beta (h)
Only Step7 v5.5 support CPUs 417-5H.
cordobes998
Ouch, I suspected from the beginning. (gogle)
Thanks!
cordobes998
Re: S7-400H redundancy application - CP443-1
Good morning,
I have a problem with CP443-1 board in a S7-400H redundant application. I need to create a new Profinet network to be managed by CP443-1 but is not possible to "Insert a Profinet I/O System". I am working with Step 7 v5.5 + SP3.
I think that this board is not supported as a IO Controller in S7-400H.
Note: I have a Profinet network but managed by Profinet Port of CPU. That network is ok.
Could everybody confirm me?
