I need the pinout for anyone of this cables from SICK. These are adapters for a programming tool PGT-10-S.
I need it in order to modify the number of lines per revolution. I just oredered from the supplier but it would take a lot to arrieve to our facility.
I hope someone can help with this.
Thanks in advance.
REQUEST: Pinout cable DSL-3D08-G0M5AC3 or DSL-2D08-G0M5AC3
loztos
vlad2006gr
Montezuma1970
Re: REQUEST: Pinout cable DSL-3D08-G0M5AC3 or DSL-2D08-G0M5AC3
DSL-2D08-G0M5AC3 cable to be used with Sick PGT-10-Pro encoder programmer. I bought this cable and found that several people do not know how to connect the M12 - 8-pin connector to the D-Sub DB9. Use of these instructions is at your own risk.https://forum.arduino.cc/uploads/short-url/u976MIXriicLz7Hl2fkMGOKKI0u.pdf
