Reopen Schneider TwidoSuite project problem help
другие контроллеры
nguyenhonghao
Post by nguyenhonghao »
Hello all,
I already copied the projects in folder "My projects" of TwidoSuite v2.31.4 software.
After that I formatted and installed new Windows and TwidoSuite v2.31.4.
But now the old projects that I copied cannot be open. The TwidoSuite said "Can not read file"
Please help me open the old projects. Thanks in advance.
Spoiler
vlad2006gr
Re: Reopen Schneider TwidoSuite project problem help
Post by vlad2006gr »
Send me the project. Check it out.
apilife
Post by apilife »
If you are using Windows 7 and if the project files are in "C:\Program Files" (protected directory), this can explain your problems... Try another directory for the project.
didierg
Post by didierg »
The projects are stored in the directory named "My project" but in order to save or archive your work you must save two things:
First a unique file named with the name of project
second a directory with the same name
both are required in order to make a correct saving !
