(offtop)
Re: Backup parameters for Emerson unidrive
Try serial communication.
0.35 Serial mode
0.36 Serial communications baud rate
0.37 Serial communications address
On panel check/set these parameters:The Unidrive SP has a standard 2-wire EIA485 interface (serial
communications interface) which enables all drive set-up, operation and
monitoring to be carried out with a PC or controller if required.
0.35 Serial mode
