[?]: Siemens S7-1200 + Weintek
LVV75
Post by LVV75 »
Is there a problem of controllers Siemens S7-1200 with operator panels Weintek?
It possible to connect 3 S7-1200 controller to one operator panel?
Russian wrote:Добрый день, подскажите возникают ли проблемы взаимодействия контроллеров Siemens S1200 с панелями Weintek?
И могу ли я последовательно подключить 3 контроллера к одной панели?
ikasimbg
Re: [?]: Siemens S7-1200 + Weintek
Post by ikasimbg »
There is o problem with S7-1200 +Weintek.
i use 1200 plc with easy builder pro.
This is e perfect combination. EasyBuilder is free.
Simulation modul may work online. This mean is working like scada without WinCC.
Да может!
Сколко я знаю можно до 16 контролера
Ркомандую всех.
guchifosco
Post by guchifosco »
Is there a way to run the OnLine Simulation without the 10 minutes time limit? Thank you in advance.
ikasimbg
Post by ikasimbg »
I know what do you mean :) there is no time limit.
you may use it like scada system. Like WinCC RT
Use EB 800 in site. There is no time limit. i use this many hours. Working.
Try it
Good Lock!
