Analog input & output 800xA 5.1 (control builder m professio
другие контроллеры
azgor_03
Post by azgor_03 »
to configure analog input and analog output, which aspect need to take in process graphics builder editor page (800xA 5.1 control builder M professional) so that operator can give set point from face plate as well as he can monitor analog value.
pls send a procudure
Linkinx64
Re: Analog input & output 800xA 5.1 (control builder m profe
Post by Linkinx64 »
The graphics aspect "DisplayElementValue" in the SignalInReal and SignalOutReal is intended to show an analog value on the graphic display. On clicking this item from a graphic display an object faceplate will be called to let operator seeing the channel/logic value and set it manually if required. (force IO signal).
