After upgrading 4.1 to 5.1 version, it has not extracted CI851 & DP coupler (simense). NOw i want to add CI851 or CI854 & DP coupler under the CI854 or CI851. PLC model PM856.
Now i am using Control builder M professional 5.1.
please give the link of hardware gsd file link & procudure of import
GSD 5.1xA for CI854
Linkinx64
Re: GSD 5.1xA for CI854
1. Download and extract files from http://support.automation.siemens.com/WW/view/en/113602
2. In 800xA system create a new hardware library (e.g. SiemensDPCouplerHwLib)
3. Right-click "hardware types" and select "insert/replace hardware type(s)". A file selection dialog will be opened.
4. Select "Profibus (*.gs?)" as file type and navigate to file from p.1 (.gse for English). A Profibus GSD file import window will be opened.
5. Click Next, edit module settings to fit existing protocol configuration, other parameters (if needed, check it in SV4.1).
6. When you're done with GSD Wizard right-click on CI851 or CI854 HW module and navigate to the newly created hardware type in SiemensDPCouplerHwLib.
spasquini
Hi To all,
i have added DP DP Siemens Coupler on CI854 profibus board but i can't find the place where i can read and write the exchange data, somebody can help me?
https://ibb.co/xSXtXQT
https://ibb.co/drkQ7Xw
Thank you very much
Thank you very much
ciscoccna
you missed some setting in step 5. Click Next, edit module settings to fit existing protocol configuration, other parametersspasquini wrote: Thu Sep 15, 2022 2:26 pm Hi To all,
Thank you very much
there are plenty of options during import process
