Hi all,
I have a Mitsubishi FR-MD-AX520-37k-10 drive in an air compressor, it is burned power section.
Now I move control board of FR-MD-AX520-37k drive to a FR-F520-45k drive.
Everything seems ok.
When I connect and control a small asynchronous motor, it is ok.
But when I control magnetic motor of compressor (Mitsubishi code MM-DF37k3-S1), the drive can not start motor, the motor only run around 0.5...2Hz and current around 90A with 50Hz setpoint
Please help me:
- Download FR-MD-AX520-37k-10 instruction manual. I only found the manual up to 7kW
- It is possible replace control board of FR-F520-45k drive by FR-MD-AX520-37k-10 drive to control the magnetic motor?
Thanks in advance.
[?]: Mitsubishi magnetic drives FR-MD-AX520-37k-10
nguyenhonghao
