Dear all,
Please if somebody help me how to convert some programs had been written
in s7 SCL .to FBD logic .
Although i select it from the view then select FBD .but it same stay in SCL languages .
[?]: SCL to FBD Convert
Re: [?]: SCL to FBD Convert
If it was opened in LAD/STL/FBD editor...that is compiled SCL code to STL and that it isn`t convertable to FBD/LAD... You need an original source SCL code, then read it a try it to write in manually to FBD....
And I`m not sure you can do it...there was a reason why author wrote it in SCL...
