Wago-I/O-check
sasko
Wago-I/O-check
I'm looking for Wago-I/O-check or Wago-I/O-check 2 software, where is possible to get ?
THX
THX
Vagabundo
Re: Wago-I/O-check
I am looking for this application also, I would be grateful for upload
Thx
monty_burns_007
Re: Wago-I/O-check
Wago I/O check v1.0 :
Wago I/O check v.3.2 :
monty
monty
stivi
Re: Wago-I/O-check
Hi
Can someone share the current version of the program WAGO I/O Check, or the file 07500458.wdd
Thank you
Thank you
apilife
stivi
Re: Wago-I/O-check
Hi
Thank you very much apilife! You are the gratest.
THX
THX
junior1978
Re: Wago-I/O-check
Hello
I search wago i/o check. Someone can help me please
Smartscada
Re: Wago-I/O-check
link deleted,
Please load again
Please load again
msegoy
Re: Wago-I/O-check
Do you still have this installation? If you can upload it again I would be grateful.
apilife
Oleksa
Re: Wago-I/O-check
Hi there
.. why I cannot download WAGO I/O -check.
I suppose my access is limited or something wrong
Oleksa
Re: Wago-I/O-check
Hi dears,
Now my problem has an another character:
Unfortunately I still cannot solve it.
There`s a problem I assume with configuration on WAGO 750-8216/040-000.
So, the question is...can I connect to WAGO by Wago-I/O check?
I use LAN patch cord for this, is that correct?
Then I found default IP in the Internet, it is 192.168.1.17, besides I`m not sure that is correct. This IP doesn`t ping.
Kindly ask to help me or point me in the right direction
To upload the picture, what should I do?
I would show the LEDs - RUN is always red.
collinsd70
Re: Wago-I/O-check
Wago IO check does not connect via ethernet, it uses a special port hidden on each WAGO header.
Oleksa
Re: Wago-I/O-check
collinsd70 wrote: Sat Dec 27, 2025 2:42 pm Wago IO check does not connect via ethernet, it uses a special port hidden on each WAGO header.
Well, how can I connect to WAGO?
collinsd70
Re: Wago-I/O-check
Use the supplied cable as I already mentioned?
