Problem with WinCC Professional v12 SP! upd2
mexas
Post by mexas »
Hi, I'm doing a SCADA project based on PC with Tia Portal V12 SP1 upd2.
When I did other in WinCC Advanced version I ran RT normally with its button, but with Wincc Professional project, my "Start Runtime on the PC" button is disable, it's only enable "Start Simulation" button.
Thats is correct? All my licenses are OK.
I need help please!
napster
Re: Problem with WinCC Professional v12 SP! upd2
Post by napster »
you have to use "WinCC RT Start". There you have to specify the project path, which is normally in your own documents - Siemens - WinCCProjects - *.hmx.
Then you can start the runtime.
Hydra13
Post by Hydra13 »
It's very interesting question.
https://drive.google.com/file/d/0B3dfV2 ... sp=sharing
On this picture you can see that I have the ability to run from Tiaportal Runtime. (TiaPortal v12 sp1 upd 2)
But I had the same problem in TiaPortal v11
