I am using Sinutrain 7.5 Edition 2 - 2009.
Around it, I have developed a Visual Basic programs that connect to the VNCK of the simulator via DDE server like it would on a real controler.
using this method, i can pretty much acces all the data in the NC.
Position, status, machine type etc etc...
Today the new "Operate" version of Sinutrain has no DDE server nor OPC server running.
https://www.automation.siemens.com/foru ... ageIndex=1
a solution implies the new HMI Programming Package for Sinumerik Operate, named "Create My HMI/3GL".
Does any one has this package
Thanks for helping
SINUTRAIN DDE Programming Package Operate need help!
villalolo
villalolo
Re: SINUTRAIN Oerate DDE OPC server Programming Package Ope
I m really desperate, is there anyone who can tell me how to connect to the Operate System?
Please, try to help, i m runnin in circle here
Or is there any body that was communicating with the 840d sl, using DDE or OPC before operate? Did you find any solution to adapt to the new Operate?
thanks a lot
thanks a lot
villalolo
Re: SINUTRAIN DDE Programming Package Operate need help!
no one has succeded to discuss with a "operate system"?
is there a way through scout?
please help
please help
graucho
With Sinumerik Operate OPC server is not available (even if Sinumerik Operate is installed on PCU50.3/PCU50.5 and connected to NCU).
Only way is as you wrote to use Sinumerik Operate programming package (now is name CreateMyHMI). You need to watch that this programming package need to be with same version as NC software version/Operate version or higher. Problem is that you need additionally to buy QT license via Siemens and enter it during Programming package installation.
But question is what you want to do with this Sinutrain? Did you tried to play with .com files and pages written in easyscreen?? It depend what you want to achieve.
BR
graucho
BR
graucho
