Hi
is there is any way to upload program from slc 5/04 with oem bit set...??
SLC 5/04 OEM bit protected
matster
Re: SLC 5/04 OEM bit protected
Hi All,
I also need help on this, i've read having another PLC or HMI on the network might be able to write directly to S1/14 to remove the bit set, but haven't been able to try.
Is there another method or app?
I've got a customer who use to have dial in support only until that company went bust and never provided the customer with backups.
They're in a tough position now unless there's a work around.
eng abdoshawkey
yes this problem i have also at my work and original program not have it so if some body reply
