Hi everyone,
I have S7-400 PLC and needs to communicate with the "Quick Panel Control (GE)". This comunication is MODBUS-RTU 4-wire, I'll use a CP-341 as a master and a slave PLC GE. I do not know how to configure the CP-341 as Master. Could someone help me?
Thanks in advance.
[HELP] Connecting CP-341 as master [MODBUS RTU]
chasalomon
dsekulic
Re: [HELP] Connecting CP-341 as master [MODBUS RTU]
You need to install Loadable driver CP PtP Modbus Master (https://support.automation.siemens.com/ ... reeLang=en). Also You need Modbus master hardware dongle 6ES7870-1AA01-0YA0 which is plugged in rear part of CP341.
regards
regards
chasalomon
Thank you for information,
my problem was I don't have the dongle!!!
deadmate1610
Is there anyway we can do it without the dongle? Or does someone have the loadable drivers for this? I have CP 341-1CHO02. The download link of these drivers will be appreciated.
Regards
Regards
indian
To communicate without dongle you need emulate Modbus RTU protocol yourself. It is possible, there isn't hard. Do you need an example or looking for hire someone?
MaxS
MODBUS RTU MASTER FOR CP340/341/441-X (NO DONGLE REQUIRED)
https://sieportal.siemens.com/en-us/sup ... ageSize=10
indian
It's very interesting. Man did the "no dongle driver" implementation of Modbus RTU for S7-300/400 CP340/341/441.
Because SIOS's forum is blocking russian and byelorussian IP, I mirrored files shared there.
link
Some times ago I did the same thing. S7-300 + CP340 read 30 chinese temperature sensors. I did much more simpler.
Comments a lot inside project (in russian). Project here.
link
link
link
indian
an error had been fixed and speed been up
here
here
