while connecting through PC to OPCA-02 cable to ABB ACS550 drive, it shows error CRC.
help me how to over come this problem
iam using to connect the drive DWL2.6
help
rajesh.putta
[?]: not connecting to ABB ACS550
xwindows2000
Re: [?]: not connecting to ABB ACS550
I want software for AC500. Can you upload.
Regards,
Regards,
Linkinx64
rajeshputta
This soft ware is get from the forum, you can type on search box:OPCA-2, you will get links.
for for ACS550 you can use DriveWindow Light software.
see the link: [dead] :/130639872/A ... w_v2.2.rar
rajesh
rajesh
MEFinc
Check the parameters of your COM-port and drive.rajeshputta wrote:while connecting through PC to OPCA-02 cable to ABB ACS550 drive, it shows error CRC.
help
rajesh.putta
rajeshputta
means we need to set PC COM port:27 & Drive COM setting port:27?
earlier post that time iam tested PC com Port:2 & Drive COM port:02.CRC error is shown.
regards
rajesh.p
regards
rajesh.p
MEFinc
You can use port number two or anyone else, it doesn't matter.
Show the parameters of your COM-ports. And screenshot of the error.
rajeshputta
Dear sir,MEFinc wrote:You can use port number two or anyone else, it doesn't matter.
sorry for my late reply,
here i can't able to upload my screen shots,
so am writing by words an error body of message:
X---------------------------------------------------------------------------X
Error occurred while identifying drive:
Following communication error while identifying drive:CRC error.
Could not identify drive.check the connections and communication settings.
X-----------------------------------------------------------------------------X
regards,
rajesh
MEFinc
Hmm, so poor information.
Ok, that may be problem like with communication settings (you set not correct value of com-port, use usb3.0 and ect.) or with software of your computer or sofware of drive...
For first, check this (from page #8.2): DriveWindow Light 2.93 User Guide
