[?]: install WinAC RTX inside VMware
genesx
HI does anyone know how to install WinAC RTX inside VMware, I tried several time but I get the message CPU not connected, Thanks
kriztof
Re: [?]: install WinAC RTX inside VMware
I tried to test WinAC inside VirtualBox. It is terribly slow, impossible to work. I think real time system is to much for virtual machine system.
obi1987
Well..I have also face some strage error while working on it.I was tested it on VirtualBox.....then I install Virtual PC and its works on it...
Hans24
found this some time ago and it worked!
The files and the original posts at siemens plc forum is here: https://support.industry.siemens.com/tf ... ageSize=101.Create VM at hardware compatibility 9 Version. (1 processor with 2 cores , 1 Ethernet Bridged Network Adapter)
2.In Vmware 9 VMX file You must add this lines (very important):
ethernet0.virtualDev = "e1000e"
bios440.filename="FUJITSU211_314.ROM"
3.Copy into VM folder file from attachment (ROM FILE).
4.Install WINAC RTX 2010 on OS
5.In station configuration Add in slot IF1 IE General card . If You prompted to install drivers from RTX then accept this. From Guest OS this card was removed. Its normal don,t panic .
6.Then From Step7 set IP addresfrom Menu --->PLC---->Edit Ethernet Node.
7. Load program and use Fully virtualized WINAC.
If You Have some problems To set IP from Edit Ethernet Node from STEP7 then You can retrive config from WLD file added into attachment. IP addres is 172.16.1.80.
