[?]: vejio designer v6.0: hardware config update problem
другие контроллеры
hmohamed
Post by hmohamed »
i have already vejio designer v6.0
but when scrolling the models of the HMIs XBTOT model is not included
how can i update my software to include this model ?
vlad2006gr
Re: vejio designer v6.0 problem
Post by vlad2006gr »
How to enable XBTOT series option in VJD6.0
Help-->License-->Upgrade and it will ask for code then please enter
VJDHTGTOPV60M
Good luck!
hmohamed
Post by hmohamed »
the version i have is v5.1.20.1404 sp2 1404-1404 and the code you give does not work
vlad2006gr
Re: [?]: vejio designer v6.0: hardware config update problem
You wrote-
For version 5.1, try: VJDHTGTOPV51M
Good luck!
hmohamed
Post by hmohamed »
the code u sent does not work
thanx
Schtiel
Vijeo Designer v6.0: XBOT
Post by Schtiel »
In Vijeo Designer 6.0.3.142 code VJDHTGTOPV60M works perfectly:
vlad2006gr
hmohame, you have determined that it is not working? To enable the XBTOT series in VJD version 5.1 there is only one code: VJDHTGTOPV51M. Show screenshot enter the code.
hmohamed
Post by hmohamed »
what serial no should i use with version 5.1?
thanx
Schtiel
Post by Schtiel »
Input VJDHTGTOPV51M and upload screenshot with error message (if any)
krank
Post by krank »
you have to download new version of VJD 6.1
Schtiel
Post by Schtiel »
But XBTOT panels were supported in earlier versions (even 4.6), see http://www.rakurs.su/news/news/news-262 (in Russian),
hmohamed
Post by hmohamed »
Schtiel wrote:But XBTOT panels were supported in earlier versions (even 4.6), see http://www.rakurs.su/news/news/news-262 (in Russian),
but the manual of the screen says it is supported in version 5.1 or later
hmohamed
Post by hmohamed »
when i use this code vjdupdtgav51m and this serial 21084610500 the model XBTOT is not supported when i tried to input your code with my serial i got a message that the code and the serial are not correct can you give me another code and serial which support this model
thanx
vlad2006gr
vjdupdtgav51m-license to upgrade from previous versions prior to 5.1. You need to install the full version vijeo designer.
Vijeo Designer 6.0.0.201 (2011)
http://www.schneider-electric.com/catal ... igner.zipx
http://www.schneider-electric.com/catal ... igner.zx01
http://www.schneider-electric.com/catal ... igner.zx02
Unpack- Use WinZIP 15 Portable or PowerArchiver to decompress the files.
Reference: VJDSNDTGSV60M
Serial Number: 12345678999
For enable XBTOT series option in VJD6.0
VJDHTGTOPV60M
Good luck!
vlad2006gr
You can try the patch from our friends from China. For version Vijeo Designer 5.1 -6.1
See http://www.52plc.net/read.php?tid=3243
Rapidshare link:
https://www.rapidshare.com/files/2789146342/Add-OT.zip
Or use Vijeo Designer Opti v4.6 or higher.
Good luck!
hmohamed
Post by hmohamed »
thank you vlad2006gr i really appreciate your efforts the patch works well
thanx again (clap) (clap) (clap)
aakodi
Post by aakodi »
vlad2006gr wrote:vjdupdtgav51m-license to upgrade from previous versions prior to 5.1. You need to install the full version vijeo designer.
VJDHTGTOPV60M
Good luck!
Tans! (clap) :D :P :lol:
mohdabshr
Post by mohdabshr »
Hi Mr.vlad2006gr
I need the OT.zip or add.OT.zip I think is same file please upload or send it to my email :
mohdabshr@gmail.com
