upload simotion d425 and cf card problem
mario_ingen
Post by mario_ingen »
connection online ok with scout
I have not the original project online by ethernet and profibus not lose the whole project achievement. sinamics_integrated1 message me offline and download the program does not download "i / o device variables"
upload al pg only a part of D425
I have installed v4.3 scout
will I need a 5611 for example? and I communicate by the Profibus interface of the plc s7 and reaches a maximum speed of 1.5 Mbps and sinamics integated speed 20 Mbs
maybe if I put the cf card in some adapter and make a picture of the data and then picked him up from the simotion scout?
there any adapter to read the cf card?
clarify pg I download the data but not the variables axles .......
Re: upload simotion d425 and cf card problem
no any way (no)
simotion not provided upload project (oo)
only basic modules (not program,cams, I/o,etc..) :(
mario_ingen
so if I have to change an engine module sinamics and that I have to respuesto is different as hardware change in the program??.
I have no way to do this without the program that is in the simotion d425?? (h)
i not checked it.i think no,but you can try:
copy entry of your cf-card with standart windows command copy/paste
change module & check if all ok
if not, copy back files of cf-card
P.S. what module you want change?
you don`t need download if use same module
ciccio
Post by ciccio »
If who download the program the first time made a full download you can upload everything, otherwise not.
if you have to change the d425 you can just move the cf card to the new one
