Ethernet in communication profilbus
Crikos
I am needing an exit ethernet in an application with s7 CPU 412, with remote ET200 saw profilbus, which the best way to have a point ethernet?
dsekulic
Re: Ethernet in communication profilbus
If You want to use ET200 on Profibus it depend on which type of ET200 You will use. You have ET200S, ET200M, ET200SP for installation in control cabinet or ET200eco and ET200pro for installing outside of control cabinet. You will need Interface module for Profibus for each extension and I/O modules. Best way is to take a look here:
http://support.automation.siemens.com/W ... 255/133200
regards
regards
