[LINK]: Schneider OFS (OPC factory Server) 3.40
RamCUP2000
Have anyone OFS 3.40 ?
SE_support
Re: Request: Schneider OFS (OPC factory Server) 3.40
I have 3.40 large, but without registration it's works only 21 days.
vlad2006gr
Please upload it to www.4shared.com or Hotfile.com? Without registration.
Если возможно, то загрузите на обменник.
SE_support
Part 1:
OFS_3_40_large_without_drivers.7z.001
Part 2:
OFS_3_40_large_without_drivers.7z.002
Part 3:
OFS_3_40_large_without_drivers.7z.003
Pass: forum name
Part 2:
Part 3:
Pass: forum name
vlad2006gr
Thank you very much, we will try.
after2702
Links are dead
Can you re upload
thank you
Can you re upload
thank you
vlad2006gr
OPC Factory Server V3.40 IE2811 SP3
http://download.schneider-electric.com/ ... =141070218
Good luck!Enhancements - Bug Fixing :
2809 Server SP1
Enhancement : Retry mechanism on datadic loading has been enforced to ensure loading completion on communication failure.
2810 Server SP2
Bug fixing : when Quick Item Validation was checked, a missing device used to be abusively reached on AddItems or ValidateItems operation.
2811 Server SP3
Enhancement : XML parser cyber-security vulnerability fix. OFS XML documents could be compromised by malicious insertion of external references (external information not contained in the original document).This enhancement disables any external references parsing.
2811 Configuration tool SP3
2811 Shared components SP3
2811 OPCUA wrapper SP3
vlad2006gr
vlad2006gr
OPC Factory Server V3.40 IE2812 SP4
http://download.schneider-electric.com/ ... 2_V340.zip
Good luck!
Good luck!
CoDa1
Re: [LINK]: Schneider OFS (OPC factory Server) 3.40
Не могу поставить OPC Factory Server v3.60 SP3 просит "Part Number" и "Serial Number"
Скачал какой то кейген, он просит "EntryNo", "CompID" и "AuxNo", - что это за номера такие, помогите плз
