I have a question about FB41 in step7 for s300.
Please can somebody answer- write to me FB41 paremeters that are neccessery for working of my system.
1. I have analog input of (measuring temperature)
2. I have actuator (mixing valve) with 2 digital outputs- left-right for water flow
mixing valve has 2 DI for tottaly left or tottaly right position. from left to right about 15 sec.
3. I have on HMI input SET point of temperature
System has very slow reaction, when actuator moves for measuring temperature reaction is neccessery maybe 30-40 sec, but it depend about lot of things it could be for abot 10 sec and it could be for a minute i 40 sec.
Can someone write me parameters for fb41 which I have to use.
And explain me everything neccessery_
With KR,
Siemens Step 7 FB41 PID regulation of temperature
stanic
PLC_ITA
Re: Siemens Step 7 FB41 PID regulation of temperature
with these indications can not give you a help.
measure temperature and then through a mixing valve, what to do?
Cool? heat? ....
best describe your process then we try to help
in each case with the FB41 can not adjust a pulse valve
Cool? heat? ....
stanic
Here is very helpful post.
https://www.automation.siemens.com/WW/f ... =en#488601
Examples of PID blocks with explanation would be very helpful to me.
With KR
Joe
With KR
Joe
