Dear Friends ,
I have CPU 314C-2Dp. Its stop LED flashes slowly when MMC is inserted into it. I have chacked same MMC working fine on other CPU. Further When MMC is inserted there is no communication between PC and CPU but if you remove MMC then CPU goes online. Please give solution.
Regards
Amit
[?+]: CPU 314C-2DP goes to stop when MMC is inserted
Re: CPU 314C-2DP goes to stop when MMC is inserted
http://support.automation.siemens.com/W ... n/29801950
Thank you very much. Solution worked fine .
Amit
Amit
