[?]: ABB ACH550 Communication problem.
привода и частотники
gsirin
Post by gsirin »
I need some help about rs-485 communication with ABB drive ACH550. For communication drivewindowLight 2.9 is using. When i try to connect to drive it gives an error.
Do you have an idea how i can fix this ?
sirtct
Re: [?]: ABB ACH550 Communication problem.
Post by sirtct »
Your drive system firmware is different from your drive window version. You need to refer to the compatibility matrix.
mandichi
Post by mandichi »
You need to update drivewindow light to new version, and also update the driver of RS232 cable. The connection on control panel port of ACH550 is RS232 not RS485.
BRs
