Dear all
I have new panelview plus 600, the default ip when it is started is 0.0.0.0 when I enter TERMINAL SETTINGS and set a new IP
192.168.20.232 and a message appare (.......... you need to reset panel to take effects)
and when I reset the panel from the main menu or from reset button from hardware the IP still 0.0.0.0
What can I do???
[?]: PanelView plus 600 IP Problem
subz3r0
Re: [?]: PanelView plus 600 IP Problem
must to be connected to a plc, switch or computer, to take the ip address
omar zedan
Thanks so much subz3r0
topa6789
it's true to reset or restart mode?
if reset, these always going to default factory mode, and when restart it will take effect for your new configution seting. it's maybe...
