Hi everyone! First of all, thank you for taking you time to read this post
This motor (AB MPL-A430H-SJ22AA) was disassembled to change the bearings and then, assembled but now, I have to recalibrate the encoder, so does anyone know how to do it?
The model of the encoder is SRS50-FFA0-S01.
did you change the encoder?
When i repaired something at motor i had used original encoder. But i can't install it the same position.
Try to use "homing" procedure. I'm not sure about all drive. I had use it only with Ultra3000 drives and UltraWare software.
