Hello
I need crack for Buddy for s7v3 or how to crack it using HexEdit.
Request:crack for Buddy for s7v3
germanfred
Re: Request:crack for Buddy for s7v3
No need to crack, it works fine for backup and restore, just some ads are in there.
mohdabshr
Hi
thank you for your replay and information , but I have question did it backup program if it is protected with password for uploading.
germanfred
If CPU has read/write protection password you need password for backup (reading) blocks. If CPU only has write password then no password is needed for backup, but for restoring blocks.
mohdabshr
Hi
thank you again.
cpu has read/write password protection , so how to crack this password did you have tool for cracking this password.
thank you again.
germanfred
There are lots of threads here do do this, but it's not easy, if you have no project. I know two way doing this, one makes an image of the memory card and reads the password from the image (never tried this) and one does bruteforce the password. If you have TCP connection you could use S7GetPwd (search web for this) to get the password. Bruteforcing is very slow for long passwords.
