I don't know part number of connector for connect item below
"1.Media Converter Siemens CODE: 6GK5101-1BX00-2AA3
with connector" 1
"2. Ethernet Switches Siemens CODE: 6GK5108-0BA00-2AA3
with connector" 1
"3.Ethernet Switches Siemens CODE: 6GK5116-0BA00-2AA3
with connector" 1
"4.TRANSCEIVER Siemens CODE: 6GK1901-0AA00-0AC0
with connector" 2
"5.TRANSCEIVER Siemens 6GK1901-0AA00-0AA0
with connector" 2
6.SIMATIC NET Siemens 6GK1104-0AA00 with connector 2
Thank you
[?+]: I need help find part number for item below
beer567
Info
- Faq & Info
Re: I need help find part numbeer for item below
GoTo https://support.automation.siemens.com/ ... earch.aspx
1. http://support.automation.siemens.com/W ... n/23282470
SCALANCE X101-1AUI IE MEDIA CONVERTER UNMANAGED 1 X 10MBIT/S RJ45 PORT, 1 X 10MBIT/S AUI SEGMENT PORT
2. http://support.automation.siemens.com/W ... n/19184097
SCALANCE X108, UNMANAGED IE SWITCH, 8 X 10/100MBIT/S RJ45 PORTS
3. http://support.automation.siemens.com/W ... n/24044019
SCALANCE X116, UNMANAGED IE SWITCH, 16 X 10/100MBIT/S RJ45 PORTS
4. old product http://support.automation.siemens.com/W ... en/4088112
SIMATIC NET,TRANSCEIVER W.2 SER INTERFACES,F. IND.ETHERNET FOR CONNECTION OF 2 TERMINALS WITH INDUSTRIAL ETHERNET
5. old product http://support.automation.siemens.com/W ... n/56972619
SIMATIC NET, TRANSCEIVER FOR INDUSTRIAL ETHERNET FOR CONNECT. OF A TERMINAL WITH INDUSTRIAL ETHERNET
6. old product http://support.automation.siemens.com/W ... n/56986769
SIMATIC NET, SSV 104 FOR INDUSTRIAL ETHERNET FAN-OUT UNIT WITH 8 INTERFACES
