[Request] Factory Talk View Studio 7.0
				gode81
Hi
Anyone knows which dll (and relative Hex code), exe and Feature to add on lic file we need to modify to have the licence working?
Factory Talk Activation is 3.6...
Thank You
Thank You
				shrddr
Re: [Request] Factory Talk View Studio 7.0
I could look into it if you share the install package
				viktar
found the links on fake:
01. http://hotfil.es/916942
02. http://hotfil.es/916951
03. http://hotfil.es/916957
04. http://hotfil.es/916960
05. http://hotfil.es/916964
06. http://hotfil.es/916967
07. http://hotfil.es/916980
08. http://hotfil.es/916982
09. http://hotfil.es/916984
10. http://hotfil.es/916988
11. http://hotfil.es/917000
12. http://hotfil.es/917005
13. http://hotfil.es/917009
14. http://hotfil.es/917032
15. http://hotfil.es/917034
16. http://hotfil.es/917036
17. http://hotfil.es/917041
18. http://hotfil.es/917048
19. http://hotfil.es/917055
20. http://hotfil.es/917056
DO NOT PRESS ANY "START DOWNLOAD" AND "FREE DOWNLOAD" BUTTONS.
Find the buttons as shown below and click on the server you what to use for download. My suggestion to use zippyshare.com was the fastest one for me.
				gode81
Thanks Viktar for the links!!
The key to modify on C:\Program Files (x86)\Rockwell Software\FactoryTalk Activation\flexsvr.exe is now on new position
Address E8F0
From 55 8B EC 83 E4 F8 81 EC
to__ 33 C0 40 89 45 FC 48 C3
And it's working (I've FTV 6.10 and new version of the Talk activation )
But the dll of the folder (as was RSwd32.dll for FTV Studio 6.10) no longer exist...
I think (MY PERSONAL OPINION!!) that probably we need to modify ftastub.dll somewhere..
EDIT: Also removed the file ftasystem2.lic, if not doesn't find the licences.
Address E8F0
 )But the dll of the folder (as was RSwd32.dll for FTV Studio 6.10) no longer exist...
				viktar
Does it mean you were able to run View Studio 7.0 activated?
Just changing the hex codes you mention above worked for my RSLogix 5000 v 20.11 but was not enough for Studio.
				gode81
No, the Studio 7.0 isn't working.
Now I've got the old Studio (6.10 because I need it) activated with the procedure found on this forum (Thanks!!) but the Factory Talk Activation 3.6.
I know that is pretty useless, but is one less problem to solve.
I wrote it to help who's going to try.
  if someone understood something else
 if someone understood something else-
				viktar
For Studio v 6 used to be:
Hexedit RSves32.dll located in \Program Files\Common Files\Rockwell
Address FBD19 From 34 02 To 30 90.
But it doesn't work for v 7
				foresighting
C:\Program Files\Common Files\Rockwell\FTACommon.dll
I'm not sure my opinion. but i did this method, NOT popup GRACE MODE..
addr = 2F619
value= 34 02 --> 30 90
plz I'm not sure. So, backup that file and did it.
addr = 2F619
				viktar
Thanks a lot! The method in a post above has worked for me.
						Огромное спасибо! Метод описанный в предыдущем посте сработал.
				prushmere
Nice work.foresighting wrote:C:\Program Files\Common Files\Rockwell\FTACommon.dll
addr = 2F619
				pembuk
Has any one recieved a warrning information about unlicenced or pirated copy of FTview 7 after activation as discribed above?
I recieved it today after several days of normal work with this software. Do I need to worry about that or just to clear this message and forget? The software is working correct now.
				peterg70
That is because the software is now starting to check for hex editing of the files.
It also means the hex edit is only the start that needs to be done so is incomplete.
It seems to only patch the acceptance of the fake license.
				viktar
Open Factory Talk Diagnostic Settings and turn all information and warning messages off, keep the error messages only.pembuk wrote:Hi,
Enjoy
				lucemiro
Can someone upload the file again 5, giving this error to download!
Thank you.
						Thank you.
				shrddr
i tried to also patch ftastub.dll but the message still pops up. have to stick with this
													gode81 wrote:C:\Program Files (x86)\Rockwell Software\FactoryTalk Activation\flexsvr.exe
Address E8F0
addr = 2F619
viktar wrote:Open Factory Talk Diagnostic Settings and turn all information and warning messages off, keep the error messages only.
				gode81
Re: [Request] Factory Talk View Studio 7.0 (solved)
Thank you to all the people that helped this thread.
I've just installed on another pc... I've just one thing to add to previous post
On C:\Users\Public\Documents\Rockwell Automation\Activations\ftasystem.lic add
FEATURE rsi.master flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:MASTER LICENSE" SN=0000000001 \
SIGN="0034 5678 90AB CDEF 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
				neziu
				ejbt
Yes, please reupload part 5, thanks in advance!
				pablo_660
Somebody would have the file 5 ?
Thank you
						Thank you
				ejbt
I found this:pablo_660 wrote:Somebody would have the file 5 ?
Thank you
http://www.myuplbox.com/file/download/856110
Downloading (i dont know yet if is the missing part), as soon as i check i will post results
				ejbt
Confirmed, missing part 5 founded is working and bellongs to set, now running FTV7, regards!
				aksay
				potter3000
Hello, where there are active links to download Factory Talk View Studio 7.0, thanks.
				catoff
Please upload again part 03, 12, 15, 16
Thanks.....
Thanks.....
				charlyman
Nice !!! Thank You !!foresighting wrote:C:\Program Files\Common Files\Rockwell\FTACommon.dll
addr = 2F619
				emanorl23
 hi!.. please give us another links for this software.. we need it so badly..
 in advance
  in advance-
				tapvovan
Please upload again parts: 3, 12, 15, 16. Thank you sir
				franklinleron
tapvovan wrote:Please upload again parts: 3, 12, 15, 16. Thank you sir
can someone upload parts: 3, 12, 15, 16 please ?????????/ thanks
				Gau_10
 Please!!
does Somebody have broke links?
				icaro14
please reupload all.  s
 s
						 s
 s-
				neojames
Could anyone reupload this software?  Thank you.
				imasd
Hi guys
Please can i tell me FTV 7 url
and .lic or patch
Thanks for your work
Knowledge is the single area of freedom
and .lic or patch
				sihnam_jp
Hi! Can someone upload these files to https://mega.co.nz/ please? thank you.
				rnkgajjar
i hv factory talk view studio ME 8.0
want to activate
which procedure i choose.
please suggest
						want to activate
please suggest
				raintiger88
Guys,  I've installed FT View 6.1 and have tried all the above previous tips, but none of them work.  My installation comes up in DEMO mode/license not found. . .can't figure this out.  Anyone with a known good file edit that works, I'd appreciate it.
				raintiger88
Disregard.  I found the answer in an older post:
C:\Program Files (x86)\Common Files\Rockwell\RSves32.dll
For Factorytalk Studio v6.10 address to activate is FC339
FactoryTalk View Studio 6.10
Hexedit filename RSves32.dll
Address FC339 From 34 02 To 30 90
				psgama
Good job. Thanks for using the search
				Vasilis93
I'm using a SLC 5/03 PLC
And v2.60.00 (CPR 9 SR 6) FT
I completed the first steps, but when I go to finish the tag
It shows me this error
And this when i try to create a new application
				mmensa
Hello. Does anyone have any working links? I need the version 7 ASAP. Please
				Cristiano14
I'm looking for Factorytalk View Studio v9.00.00, does anyone have it? Can someone help me?
Thanks!
						Thanks!
