Hallo,
i am a user of Simatic Software since a lot of years. Never i have Problems with EKB Install ...
In this Time i install TIA from Original DVD (Step 7 v12 Professional, Wincc Basic V12 ...) and use the latest Version of EKB install (08.03.2013) it works!
For Migration from a existent Projekt i must also install Step 7 v5.5 and Wincc v7SP3 from this Forum.
Installation Step 7 V5.5 works fine.
Installation Wincc V7SP3 is also ok.
Then i install WINCC V12 Prof (before this Installation i delete WinCC Basic V12) - the Installation will not work: "WINCC V12 is not kompatibel with older Version Wincc V7 SP2 or before"????
I install Wincc V7 SP3!!!!!??????
Also i delete WINCC V7SP3 and in this Moment i can install the Version WINCC V12 Prof.
The Installation is korrekt - not the Licence!
I downloaded the latest EKB install (26.5.2013)!
Step 7 v5.4 is ok!
The follow Key are missing in Simatic ALM: TIA komplete (Step 7 V12 Prof, WINCC V12 Prof and also Step 7 V5.5 ....
What is the Solution for the Problem??????
Never Time before i have this Problem!!!
Thanks for Answer.
[?]: TIA v12 and Step 7 Licence Problem
trb0_1
Re: [?]: TIA v12 and Step 7 Licence Problem
Hallo CoMod,
i think also that i am the problem.
I read the Threads in your post before you are writing this!
in my last post i forgot: im using win7 64 bit prof.
The Problem is existing: the EKB install is not working!
Step 7 v5.5 is korrekt with licence - all other (TIA V12 ) will say: no licence in ALM!!!)
Anyone have Idea?
Anyone have Idea?
this is your personal problem with your BLA-BLA-BLA....trb0_1 wrote: i think also that i am the problem.
Screencopy with not working EKB installtrb0_1 wrote:the EKB install is not working!
Really ?trb0_1 wrote:I read the Threads in your post before you are writing this!
When Screencopy ?
TIA error ?
AX NF ZZ ?
ALM ?
trb0_1
http://s14.directupload.net/images/130609/gtpuv7ke.jpg
http://s1.directupload.net/images/130609/6buqzaph.jpg
http://s14.directupload.net/images/130609/inqytlfy.jpg
http://s1.directupload.net/images/130609/szrzws7j.jpg
http://s7.directupload.net/images/130609/xrv3qz6v.jpg
only Pictures - not Bla-Bla!
Start without installed keys = Error
Installed 1 key
Start without errors
and work
and ReRead forum topics
viewtopic.php?f=4&t=11415
viewtopic.php?f=30&t=218
Installed 1 key
and work
FIRST READ HELP FILE !!!!
