hi, i use cx supervisor V3 but when i run my project i have the same error
"communication started in demo mode and will be disabled in two hours ""
also when i open cx supervisor "la mise a jour du registre de systeme a echoue.essayee d'utiliser REGEDIT "
						[?]: error cx supervisor
				Carlos
Re: [?]: error cx supervisor
friend just a bit before starting, it is not an error, it is an information that you are using a demo version and the serial number works in the developer but not in runtime.
More search in this forum and you will find solution
  go to PM
				missfafa
what i can do for have a run time cx supervisor full version
i install the dongle usb for cx supervisor v3.0 but i have the same probleme demo in two hours
