Does anyome Know the Pinouts for a ASIMON Download cable ASM-DC1.
It as a Rj45 connector at each end . Can a Normal Ethernet Patch lead be Used ?
[?]: ASIMON Download cable
flashy
Re: [?]: ASIMON Download cable
Yep, chop one end off, and solder into a 9 Pin D sub connector, to connect to your PC's serial port.
illiterate
Thanks flashy
I presume this pinout is for the serial programming Lead used Program using the ASIMON Software.
I was also Interested in the Lead used to automatically transfer a configuration from A Existing Device to a new replacement Device.
keygen
