Посоветуйте, как решить проблему: при переносе Step7 проекта с одного компьютера на другой некоторые нетворки из FBD преобразуются в STL.
Версии Step7 и Windows на обоих компьютерах одинаковые.
[?]: FBD partially converts to STL
When open FBD project i view it in STL
Re: FBD partially converts to STL
You have to make this networks simplier by editing them in STL.MikeMMM wrote:I'm stumped, please give me an advise: after transferring a project to another PC some FBD networks somehow had been partially converted to STL. Installed software are the same on both PC.
When in the LAD/STL/FDB editor, go to Options >> Customise >> LAD/FDB window and turn off the "Type check of Addresses". please note if you make any errors with data tyes they will not be highlighted.
