Helping with my final project
alketbi
Post by alketbi »
Hi guys
I need help from you
this is my last year in the university and I have a final project which is automatic controlled system
here you can read the Principle of Operation of my project :
(you can see the diagram)
The Concept of this project starts from the field where there are some soil moisture sensors and it begin when the soil gets dry the soil moisture sensors will sense the moisture in the soil and the sensors will send signals to the PLC for taking an action and the Dry soil LED will be on to show that the field need watering. The PLC will activate the water pump and PLC will choose the water path by opening the solenoid valve for the needed field. On the other hand, The PLC will not operate the pump unless there is enough water in the tank. By using a level sensor otherwise the water pump will burn if the tank is empty. Moreover, when the soil gets wet the soil moisture sensors will sense that and that will be shown in the saturated indicator LED. Also, the Start and Stop Push buttons will be exist to active and stop the system.
the problem is how I can do the ladder diagrams for PLC???!!!
and I have 7 inputs and 12 outputs, what is the best plc module should be used ( I mean the fixed or the small plc ) and how the connections will be ?
Really I need help from you I have every thing expect the programming.
PCNightmare
Re: Helping with my final project
Post by PCNightmare »
Maybe start with free software?
http://www.ab.com/linked/programmableco ... loads.html
What do you study?
pino2003fr
Post by pino2003fr »
could you describe the hole process may we can help you
peterg70
Post by peterg70 »
so you are at uni and you have a project to do which is part of you course.
But you have problems writing ladder code.
Isn't it part of the course to write ladder logic?
LenPatrick
Post by LenPatrick »
Hello, I can help you however need to know if the sensors are Analogue and need to know the step by step in a more simplified manner.
The ladder I end tonight even if it is in your best interest.
soundview00
Post by soundview00 »
We can point you in the right direction, but will not do the work for you.
This is where your 'Digital Logic' course come into play.
This is where your AND, OR, NOT, and IF statements comes into play, this is where you demonstrate that you understand the work and the task at hand.
For starters I suggest that you create a 'Truth-Table' first and start from there.
BTW: most ladder logic software have some really good documentation.
