[?]: Activation of Studio 5000 Logix
nrjdsn
Post by nrjdsn »
So I watched this in post of the messer in other Forum and I wanted share with you.
Try to use the following...
Note*) The new Studio 5000 V21.0.0.0 from now on uses digital signatures to protect the files.
This method will work for now on.
Factory Activation Software 3.51.0.0040
Show
Use FLEXnet Licensing v11.10.0.3 build 96515 i86_n3 (lmgr.lib)
Patch to allow licenses:
Hexedit flexsvr.exe at address E4D0
Replace 55 8B EC 83 E4 F8 81 EC with 33 C0 40 89 45 FC 48 C3
Patch to accept licenses:
Hexedit C:\Program Files\Common Files\Rockwell\FTACommon.dll at address 40FB9
Replace 34 02 with 30 90
Patch to bypass digital signature check:
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ActivationInterop.dll at address 5C86
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\LogixDesigner.exe at address 1DFAF6 (V21.0.0)
Hexedit C:\Program Files\Rockwell Software\RSLinx\RSLINX.EXE at address D9092 (V3.51.10.00)
Replace 0F 85 46 03 00 00 with E9 2C 00 00 00 90
It now shows a message stating that files have been altered.
The following will remove these messages:
Patch to bypass digital signature warning message
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\RSLinx\FTAStub.dll at address FCD
Replace 40 03 with 09 00
Quote:
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
I tested and the software run very well.
I put archive in 4shared, you'll need put the archive in folder and update license.
for ex:
there is a archive in folder with "LogixDesigner.exe" name. Is olny put in folder:
And replace old archive.
http://www.4shared.com/rar/-QyWtKks/AB_S_5K_L.html (dlink)
peterg70
Re: Activation of Studio 5000 Logix
Post by peterg70 »
You have got to be kidding that it first appeared over in the other forum.
That had already appeared on this forum before messer stole the information and presented as his own
This can cause the cracker to no longer post as people post their work as their own.
The information is already on this forum.
mdim
Post by mdim »
Hi all, I read the original post of messer and there in the bottom I found
Follow also considerations above....thanks peterg70
peterg70
Post by peterg70 »
That is because I informed him to stop stealing information without crediting this site.
All he did was reference me instead.
No where does he credit that the information was taken from here.
nrjdsn
Post by nrjdsn »
Independent what people show in site. I was very happy with post and I shared with other forum, because I saw that many people had same doubt.
Thank you!!! (oo)
gode81
Post by gode81 »
Hi to everyone. (nuser)
First of all thank you to share this!! It worked for me.
But now I need to upgrade the Factory Talk Activation to version 3.6 in order to install Factory Talk View Studio v7.0.
After upgrade the View Studio work fine, but Studio 5000 give me a week of work.
I tried to downgrade Factory Talk Activation to version 3.51 follow the procedure and View Studio is in Demo mode (5 displays!!) , but Studio 5000 works fine.(h) (h)
So I can use one properly only one program...
Do you have any suggestion?
Thank you so much
alukarddude
Post by alukarddude »
I'm sorry, i cant understand what to do whit the FLEXnet part, if you could give me a brief explanation of what means that part it would be great.
and another thing, right now I'm using it in a grace period for a project for my school, but i want to connect a 1769-l24ER CompactLogix, but when i try to upload or download i get the error mesage
"The controller you requested contains firmware revision 1.03. logix designer support for this revision is not installed."
but i installed all from the studio 5000. can you help me with that to.
wuddy
Post by wuddy »
Dear nrjdsn
Quote topic in the PRODUCT_NAME:
Show
We should to change the RS5K_700.exe to RS5K_000.exe.
You can see in My Computer>Local Disk (C:)>Users>Public Documents>Rockwell Automation>Activations. So double click at ftasystem.lic
Quote:
Show
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_000.exe" SN=8283999999 \
To check that you've done things right, open yur FactoryTalk Activation Manager > Advanced > Refresh Server. Then click the 'Manage Activations' tab and then 'Refresh Activations'. If all went well, you should now have RS5K_700.exe, RS5K_GLX.exe, RS5K_MLP.exe, RS5K_000.exe,RSLINX.EXE and RSLINX.EXE GW (where GW is Gateway) as an Availible Activation.
bilbo_321
Post by bilbo_321 »
Firmware 1.03 is the basic firmware. New PLC is delivered from factory with this firmware and you have to upgrade it using ControlFlash program. This is the first step.
READ FIRST THE MANUAL: http://literature.rockwellautomation.co ... _-en-p.pdf , Chapter 4 !
nemanja90
Post by nemanja90 »
Can somebody help me with the activation? The instructions aren't very clear. The package from 4shared is edited with the Hexeditor, right? Where do I copy them? Whatever I do, I don't get any activations in the the Activation Manager. And what is the part in the quote on the first post? Thanks.
Bitlogic
Post by Bitlogic »
(nuser) Well I was so impressed with work people have done on the V21 Activation... I had to try it. Downloaded Studio5000 and the 4Share rar and set about replacing all the supplied files into the appropriate directories. All the licenses appeared but I cannot borrow any from the server ???? I've rechecked the crack files and they are all in the correct place. Activation Manager just won't use the licenses ???? Can anyone suggest a workround??? Cheers to all (oo)
Valleyman
Post by Valleyman »
Where did you dl the studio 5000 ? I need that link urgently :D
Bitlogic
Post by Bitlogic »
:anon: Read all these posts... viewtopic.php?f=12&t=19093
jamesdine
Post by jamesdine »
please can anyone make it little cleared.
should I replace the file in ab_s_5k_l (like flexsvr) with the original ones. or do all the haxedit and ignore the files?
thanks
Bitlogic
Post by Bitlogic »
Replace all the files with all the ab_s_5k files in the directories shown... or do the hex edit yourself. Much easier to just replace the files (rename the originals with the extension "old")
arfineira
Post by arfineira »
Thank you very much everybody..!!! for explain the procedure (clap) (pgood)
frankw
Post by frankw »
jamesdine
Post by jamesdine »
what is the emulator working with v21, any body has a link, thanks again
EverLiving
Post by EverLiving »
Hi All!
I installed Windows 7 64bit and Studio 5000 21.00.01 after tried use this activation,
but program showed window "Product Activation Failed" with warning "period will expire..." (h)
Could you please help me. (oo) (sos)
What I doing not right? (h)
I replaced all files according instruction. (read)
Thanks!
EverLiving
Hi ALL!
Please ignore my previous message.
I found my mistake.
Now all working.
atm1978
Post by atm1978 »
hello everliving. im still getting the 'activation failed error msge for my studio 5000. please tell what what u did to fix your problem. thanks in advance.
ferjuarez
Post by ferjuarez »
Hi!
I have the some problem:
gode81 wrote:But now I need to upgrade the Factory Talk Activation to version 3.6 in order to install Factory Talk View Studio v7.0.
Any solution??
Thanks!
peterg70
Post by peterg70 »
It means you have not done something right.
Check if the changes to the file have been done.
run a command prompt and cd to directory then type FC orig.dll modified.dll and it should show the differences.
also check the log file generated by the security manager.
atm1978
Post by atm1978 »
i have replaced all files with the ones in the crack but still it gives a messege that activation failed and im using it in grace period. im not sure what im missing. pliz help. during installation which serial nuber should i use? is there more to whats in the crack that needs to be done. if so pliz help.
thanx in advance
mezippy
Post by mezippy »
Hi All,
Can anybody let me know if this works with Studio 21.00.03 as i have done as explained and have downloaded the files, however the files are for 21.00.00. Has this C***k been patched in 21.00.03.
Thanks.
ivogd
Post by ivogd »
Did you find some solution for that ?
I have to install FTView Studio on VMPlayer with other OS in order to be able to use it properly ( you can activate Logix 5000 v.20 with Studio 5000 (v.21) and FTA 3.51 works, because Logix 5000 is a Studio 5000 component) ..
But, still no solutions to activate Studio 5000 with FTA 3.6 or to activate FTView 7.0 with FTA 3.51.... not on the same OS at least...
Even I have problem with Logix 5000 v.20 .... when Studio 5000 (v.21) is installed over v.20, I got error msg and after that Logix 5000(if you using v.20) crashing - some problem with EDS library files...
Can you share if you find some solution for FTA 3.51 and FTA 3.6 ?
davmazi
Re: [?]: Activation of Studio 5000 Logix
Post by davmazi »
Hey I would like to add myself to request. Anyone knows solutions for FTA 3.6 ??
peTerjuan
Post by peTerjuan »
(sos) (sos) (sos)
bakosric
Post by bakosric »
Hello Everybody!
I need some help. I just download the studio 5000 21.00.01.iso. But not crack in the file. Somebody please sent to me the crack, and a little description about what can I do with the crack.
Thank you Everybody!
Best regards:
Richi
jaaqob
Post by jaaqob »
Hi!
I managed to install studio 5000 on Win8.1, but after replacing crack files i'm still without licences. Only grace period.
Maybe for newer Windows versions something more should be changed?
Coulombboy
Post by Coulombboy »
Thank you for posting the procedure. I was able to activate Studio 5000 i have downloaded from the links given on this thread viewtopic.php?f=12&t=19093&p=70840&hili ... 000#p70840 (the mega is working, credits to matro05).
I have replaced the files stated but was not able to make it successful at first. The last thing I did was to copy the statements below the "quote:" on the procedure and copied to the FTAsystem file found on user\public documents\ rockwell automation \ activations. After saving i have restarted studio 5000 and voila, the product was activated.
Thank you very much for posting and credits to the original author of the procedure.
(tyou)
CoDa1
Post by CoDa1 »
Install Studio5000 v.21, crack - ok.
but after installing RSNetworx v.24 the activation fell off and the desired address in the files are the other numbers
Help
broken copied the files from another computer, and the folder with RSLinx, as it is when you install RSNetworx v.24 installed RSLinx v. 3.71. It worked, but RSNetworx only runs in a demo mode
скопировал ломаные файлы с другого компьютера, и папку с RSLinx, так как он при установке RSNetworx v.24 установил RSLinx v. 3.71. Все заработало, но RSNetworx запускается только в демо режиме
RobotVolta
Post by RobotVolta »
Hello, I read the posts about activating studio 5000 V21.
Now I installed studio 5000 V24 and want to activate it.
Are the same files and same hex stings (with a different address) to be change as with V21?
Has someone already a small description of the procedure for V24?
Thanks.
kamalchennai
Post by kamalchennai »
Please help me to get Studio 5000 Logix V24.00 (sos)
CoDa1
Post by CoDa1 »
напиши в личку е-майл - вышлю, там образ
asteroidehk
Post by asteroidehk »
Hello Friends
Somebody has Studio V24 Working?
I have followed the instructions, but the addresses and values are different.
Can somebody help us?
Thanks a lot. :mrgreen:
basavarajukm
Post by basavarajukm »
I have also installed V24 tried to activate but failed please let me know if you are able to activate.
cuongvcs
Post by cuongvcs »
Hello everyone.
Can you please tell me how to activate Studio 5000 V23?
many thank.
gazzeto
Post by gazzeto »
How to activate RSNetworx v24, help me pls
nnduc
Post by nnduc »
anyone help me to active studio 5000 v27 pls
Cristiano14
Post by Cristiano14 »
I'm looking for Factorytalk View Studio Site Edition v9.00.00, does anyone have it? Can someone help me?
Thanks!
prasanthen
Post by prasanthen »
Can anyone share the Studio 5000 V.30 activation procedure.
Many thanks,
al3j5ndr0
Post by al3j5ndr0 »
