Data direct 800xA
Data direct 800xA
I'm searching for the data direct plugin VB code. It's seems it's protected and i don't know what tool/approach to use in order to reveal the contents.I need it to understand connect mechanism with the 800xA in order to implement something myself. Thanks for any ideas and supports fot the people with knowledge in this subject!
Re: Data direct 800xA
Linkinx64 could help you.
Use VBA backdoor option in AOPR to remove password from the protected excel shit.
AOPR can be downloader from http://rutracker.org/forum/viewtopic.php?t=494573
I can upload it on any file storage server in case you are having troubles with tutracker.org
Hello Linkinx64,
Welcome back to forum. Are you finish your project commissioning?
Please upload AOPR tool to mediafire or 4shared.
Thanks.
Thanks.
Not yet. Here is the AOPR with serial number : http://www.mediafire.com/?9338qzda8bhspgttuangp wrote:Are you finish your project commissioning?
Thank's for the link. I hope it will work.
Hi Linkinx64,
I need your help for "How to create automatically report when alarms&events occurs by DataDirect tool?".
Could you explain the concept of alarms&events report?
Many thank,
Tuan.
Many thank,
Tuan.
