Greetings to all!
is anybody have 24MB MMC card image to share? and i planed to use with normal SD card with s7imgwrite1.
i need to update firmware 1.0 to latest firmware.
Original 24MB mmc card is very expensive and think alternative way to do it.
please give me any suggestion, thanks in advance.
[?]: 24MB MMC card image and nonSiemens SD card
pmmdavid
Info
- Faq & Info
Re: anybody have 24MB MMC card image to share?
it impossible
For this Siemens cards is Gold
pmmdavid
thanks in adv.-
flashy
Re: [?]: 24MB MMC card image and nonSiemens SD card
Hello
You cannot use a standard SD/MMC card in the S71200 or any Siemens PLC.
The offical Siemens units ave a header written into them, that cannot be written to using a standard PC card writer.
You can use a Siemens Field unit that will use the official Siemens cards, or by using a standard PC with IMG R/W tool but you will have to have another original Siemens card , otherwise the PLC detects and looks for the unique header , if it cannot see it, the PLC will not run,
Sorry but unless you know , or anyone else, can find out, never been possible..
##~FlashY~##
##~FlashY~##
