Now, there is a Page available, which shows you all application and engineering examples for SINAMICS G, SINAMICS S, SINAMICS V and other drives.
The sample applications provide:
- Reusable blocks for scaling the setpoint and actual values
- Explanation of the configuration steps with screenshots
- Reliability through previously tested programs and blocks for parameter access
- Significant reduction of commissioning time
- Detailed described documentation with parts lists of the used hardware and software items
You can set the filters in combination with drive type, PLC, communication type between drive and PLC, drive function and so on.
