Hi.
Can't work with simulation module.
I choose PLCSIM local on a plcsim panel, after make PG interface on a Simatic Manager and set a same configuration-OK,
choose a download to PLC,and open exicting project.
When I try set a online connection have message "not possible online with CPU".
What I do wrong?
Very thanks.
[?+]: Can't work with simulation module PLCSIM
Re: PLCSIM
Is PLCSim running when you try to download to it?
(SIMATIC - Step7 - S7-PLCSIM Simulating Modules)
http://support.automation.siemens.com/W ... _en-US.pdf
4. Getting starting
Select PLCSIM(MPI) or PLCSIM(Profibus)
4. Getting starting
Re: [?]: Can't work with simulation module PLCSIM
Thanks,now its working.
