[?]: OP77A clone o another identical OP77A?
rodman
Post by rodman »
Hello All!
Is it possible to load program from OP77A to PC and then load this dump to another identical OP77A? Will it work?
Any other ideas how to clone the device?
Device is 6AV6 641-0BA11-0AX0, connected via profibus to S7-314C-2DP (did not check dip-switches, might be mpi on profibus cable)
Thank you for replies!
Info
Faq & Info
Faq & Info
Re: [?]: OP77A clone o another identical OP77A?
Post by Info »
rodman
Post by rodman »
I knew all the time that this forum is THE BEST place on Earth to get a professional advice!
Thanks a lot!
