[?+]: MP 377 12" Touch Transfere - stop on 90%
omar zedan
Post by omar zedan »
Dear All
I use WinCC Flex. to build and transfere project to MP 12" touch, When I Transfere the project, its transfere (about 90%) and ended with message error (..... there is no memory card )
I did not use a memory card, How Can I fix this error???
Umencho
Re: [?]: MP 377 12" Touch Transfere - stop on 90%
Post by Umencho »
You can try it with some very simple project...You already made reset to factory settings, right?
BR
peterc101
Post by peterc101 »
you are trying to download a memory card file ( .pdz ) to a panel without a memory card
when you make transfer uncheck transfer of the .pdz file
omar zedan
Thank you, its work now
Thanks for your interest and help
I solve the problem by changing the version of WinCC Flex to SP2
- In transfer I use Device Status button the version is 1.0.4 (of the panel)
-I install the SP2 (the image is 1.0.4 too)
-I make transfer but the transfer 90% and stoped then I change the setting in Panel (Transfer --> download path "or some thing")
and its worked.
