Siemens Touch panel
omar zedan
Siemens Touch panel
Post by omar zedan »
Dear All
I use wincc flexible 2008 to built a project for a touch panel 377 12" ,
The Wincc Flexible
Version 2008
Build V1.3.0.0_1.83.0.1
The panel order number 6AV6 644-0AA01-2AX0
When I use Transfere the program ask me to update the OS of the device
When I use Transfere the OS Update the Message
"Cannot perform Restore opertion. Backed up file(s) not compatible with the operating unit.
(not_allow)
Check the operating system version and hardware configuration of operating unit"
What Can I do to fix this problem????
Re: Siemens Touch panel
1. Archive project to ZIP
2. Install SP3 and update 3 for SP3
Build=1.4.3.0
viewtopic.php?f=36&t=8650&p=57737#p57737
http://rutracker.org/forum/viewtopic.php?t=3957237
omar zedan
I will try it.
omar zedan
Dear CoMod
I install winccfex 2008 SP3 and update 3
and the version become
Version 2008 sp3 upd3
build k01.04.00.03_01.05.00.09
and the problem still the same
Photo of panel label ?
omar zedan
Dear CoMod
unfortunately I stick in this factory in very far place from cities and I have not camera therefore I wrote evry letter in the panel plate.
SIMENS
MP 377 12" Touch
1p 6AV6 644-0AA01-2AX0
S C-C2C73948
MAC-ADD.:00-1B-1B-1C-DA-79
APPROVED
CL.I,DIV.2GP.A,B,C,DT4
Type 4X/12 INDOOR ONLY
II3D Ex tD A22 IP66 T70
KEMA 06 ATEX0266X
EStand:11
Made in Germany
Listed 3DA1
IND.CONT.EQ. For Haz.Loc.:
LC.I,DIV.2GP.A,B,C,D T4
LC.I,Zone 2,GP.IIC,T4
Encloser type 4x,Type 12
Indoor use only, Watertight
Input DC 24/1.8A max
KCC-REM-S49-HMI
Ta: 0C..+50C Vertical
http://support.automation.siemens.com/W ... en/5827904
Warning: transfer of the configuration via MPI/PROFIBUS
If the operating system of the panel is already compatible with the version of ProTool used, you must check the MPI/PROFIBUS addresses used of the PG and panel.
If the panel and the PG happen to have the identical MPI/PROFIBUS address, the transfer is also aborted with the message described.
ProTool = Flexible
omar zedan
Dear CoMod
I use ethernet port in my laptop with address 192.168.1.70 and I set the IP address of the panel to 192.168.1.1 and I ping it and there is areplay. and I didnot use MPI address.
What can I do know????
omar zedan
Dear CoMode
I use MPI addapter with address 0 and select the MPI address of panel 12 and the problem still the same.
Sorry to boring you but I appreciate your helping so much.
